HighlandStorm
Printer Keeps Setting z15 for first layer?
Hi guys,
Sorry to post again so soon.
Thanks to everyone who helped me before, the printer is now doing things - moving/heating/extruding plastic all over the place.
However, now it's setting Z15 as the start height for the print, which is 15mm above the bed. I've tried using global offset to compensate for this weird gcode, but the global offset doesn't seem to do anything to my printer.
I'm using a Davinci 1.0a with repetier firmware.
Any ideas on how to solve this odd gcode issue?
Thanks!
brian442
Re: Printer Keeps Setting z15 for first layer?
I would go back to Help > Configuration Assistant, and re-download the settings for the da Vinci 1.0. The stock settings for that printer already work well, so you should need to make any other changes. Perhaps that will fix any accidental settings that are current wrong.
