Andre267
Missing Triangle
Hi i tryed to Slice this Thing and this is what i get :(
https://gyazo.com/ef9d7cbdbc1d81ec7f41fd872b16730c
Thing:
http://www.thingiverse.com/thing:1785205
STL File:
Bowden_v2_Circular_Fan_Duct.stl
I already tryed different Layerheights but it dosen't work. :(
brian442
Re: Missing Triangle
Did you try running the repair checks in S3D to see if there are issues with the mesh?
The issue is simple, really.........wall thickness!
If you modify the wall of the duct so the wall is thicker, it will slice correctly.
S3D is designed to not print walls that are thin. Add your thoughts to this thread: viewtopic.php?f=23&t=3471
Attached is the modified stl that will print correctly at 0.1mm layer thickness with a 0.2mm nozzle
Bowden_v2_Circular_Fan_Duct_1.stl
(1.4 MiB) Downloaded 167 times
