Baudrates: How fast or slow?
Posted: Mon Feb 17, 2014 11:41 pm
by MrWayne
Hi There...
before anyone asks,I have a FlashForge Creator Dual on Sailfish 7.6 firmware. And I predominantly use a Mac on 10.9.
As an exercise towards setting up a workflow, I am running via USB and the Machine Control Panel. I have four points I am interested in solving.
1: Complete dead stop during a print. Unrecoverable due to software locking up.
2: Intermittent pauses during print. (yes, I have read the post about short filenames etc)
3: Best baudrate to use. Currently defaulted to 115200.
4: Temperature Plot does not show bed, only extruder.
I have also noticed that if the Machine Control Panel is not the window in focus, after a while (was surfing with Safari) the print paused. When I focussed the window, it started again.
Any help here would be graciously accepted.
Re: Baudrates: How fast or slow?
Posted: Tue Feb 18, 2014 12:22 am
by jimc
1&2 you should always be printing from your sdcard not the usb. Computer processes can disrupt the data transfer to the printer. Always sd! #3 is the correct rate. Atleast for my printer. The ff might be different. Youll have to find that out from ff i think. #4 do you get a temp reading back from the bed? The digital #'s?
Posted: Tue Feb 18, 2014 1:59 am
by MrWayne
JimC...
I absolutely know that SD is best. And that's how I have been printing since I purchased the printer two months ago. As I said, I'm experimenting with a new workflow. Particularly from a remote perspective. I can use remote desktop to load and run files. It also allows me to monitor the printer.
Interestingly, only after I altered the baud rate higher and then back to default does the bed temp now display.
I am wondering how the SD card functions work. Are they functional?
Posted: Tue Feb 18, 2014 6:11 am
by JoeJ
Just to be sure, did you follow this guide?
http://www.simplify3d.com/support/makerbot/
Particularly the part where you select the MakerBot/Sailfish firmware settings. You will need to choose the "Replicator 1 - Dual Extruder" on the X3G tab, otherwise you will have problems trying to use both extruders and the heated bed.
Posted: Tue Feb 18, 2014 3:57 pm
by MrWayne
Joel...
Thanks for the post, and yes that's already done.
Everything was running great for a few hours, knocking out two prints. Each print was about two and a half hours long. Then on the third print (same file as the last two), S3D locked up and froze the print. The head was actually embedded in the print.
I had to force quit the application (on a Mac) and also reboot to get S3D to start. I restarted the print and it failed again, with the same deal.
Seriously, USB can't be that bad..???
Posted: Tue Feb 18, 2014 7:56 pm
by JoeJ
Check the Communication log in the Machine Control Panel. Do you see a bunch of communication issues with the bot? Things like lost packets and failed transmissions?
Many times that says there is some problem maintaining a constant USB connection. Power fluctuations and EM interference are big causes for this.
Posted: Wed Feb 19, 2014 12:34 am
by MrWayne
Joel...
Is there a log file..??
Cheers..!!
