Glacian22
[ADDED] flowrate for infill and bridging
It would be really helpful to have the flowrate/line width for infill be adjustable, that way the actual percentage could be kept low while still maintaining nice rigidity. Kisslicer has this, and it's a really nice feature.
Also, I see that for bridging you can set it to run at a lower percent of the normal flowrate, but it would be great if you could go *above* 100%. Normal yes, you do want to lower the flow to help reduce sagging while bridging, but on very fine layer heights (.1mm and below), I've found that the trailing line often snaps before successfully bridging, and increasing the flow can really help.
Thanks!
Re: Feature Request: flowrate for infill and bridging
The flowrate for bridging and infill are both now adjustable as of version 2.2
