Print in same direction for perimeter shells
Posted: Fri Feb 03, 2017 9:14 am
Would it be possible to print the perimeter shells and the infill all in the same direction? Like either clockwise or CCW.
It actually kind of works already for the inner shell and the fill, but the extruder changes direction on the outer shell.
I am making dust ports and they do not need supports or any other features. I am using a precise thickness to allow three perfect layers to make up the part. Nice and strong in Pet G. The change of direction causes a seam. I have the seam pretty small now, but would like to eliminate it. Vase mode doesn't really have a seam except with height change, but that is usually either not visible or not nearly as pronounced as a direction change.
Lee
Lee
