Parametric Infill Generator
Posted: Sat Feb 04, 2017 11:24 am
by SPRINGFIELD-JACK
Parametric Infill Generator similar or better than Zbrush Noisemaker plugin.
Re: Parametric Infill Generator
Posted: Sun Feb 12, 2017 4:19 pm
by LETUmakerlab
What do you mean by "Parametric Infill Generator"? Are you thinking variable infill density within a layer (say 30% at the outer walls, but only 15% in the middle)? Or variable along the vertical axis of the part?
I would like to have the ability to insert variable infill densities in either the XY plane or vertically.
Posted: Sun Feb 19, 2017 1:40 pm
by SPRINGFIELD-JACK
I was thinking more of modifying the pattern of the infill through noise generation like this in Zbrush:
https://youtu.be/A7ter6hcTIA
Variable density through XYZ should be possible. MeshMixer does something similar with gradients.
