Multiple objects and processes
Posted: Mon Feb 06, 2017 11:59 am
Hello,
I'm using Simplify3D and I'm using several objects (from STLs) and två different processes (one with 20% infill for the larger parts and one process with 100% on some smaller parts).
I have them interconnecting to form one item.
Is this wrong? Sometimes (not always, maybe once in four) I get a XZ-dispacement (approx 5mm) after 3-5mm high, wich messes the print of course.
A collegue of mine says that you must have one STL when you print (not several that I have) and if you have several objects they must not interconnect, especially if you have several processes.
Is this the reason for for the error or is that something you are able to do in Simplify3D?
Slicing seems to work fine without error and most print work fine.
Am I doing it wrong? Must be only one STL or can I build my print on several objects together?
I'm making my STLs in Blender using PLA on a CraftBot2.
