Three first layer issues that I am experiencing:
1) First layer height have read does not affect extruder flow rate. It is suggested for better bed adhesion to lower Height to 90%, thus same extruder flow going into a tighter height results in the bead to spread on the bed. But also read that settings of 200% Height would help in adhesion for thinner layers, but if the extruder is not compensating all you get is the very bottom of the bead to just touch the bed....worthless.
2) When you increase First Layer Width to say 150% you can see on the screen the 1st layer traces are fewer, wider apart and show as being fatter but when it prints the traces are the same diameter with wide gaps between them. Can really see the issue when you take it to 200% you just get traces that are strings with big gaps. What is the purpose of increasing the width to get a better adhesion if the traces don't touch?
3) When adding a brim to the object they show on screen and print at the normal (non-first layer height & width) thickness. The brim first layer should be affected by the first layer settings. Thus due to the issues with the First Layer Height & Width settings vs. extruder rate, am not getting a good attachment between the brim and outer wall.
Seems like the only way to get a thicker bead to fill in the desired First Layer bead Height and Width setting would be to increase the Extruder Multiplier way up, but this would affect all of the extrusions. If this is the intent of the software, they need to add an extrusion multiplier to the first layer setting box...or better yet make the extruder compensate for the height and width settings automatically.
If I wanted a fatter and taller first layer bead to get better bed adhesion and to compensate for slight bed level issues, I would increase the First Layer Height and Width and the extruder would automatically flow more filament in to fill in the increased area in proportion to the increased desired area. That way once you have your normal extruder multiplier set after calibration one should not have to adjust that setting much at all.
If I need to prevent curling of the first layer(s) and I add a brim it should be affected by the first layer settings so as to have just as much width and height to ensure the same bed adhesion and connection to the print object outer wall.
Hope someone can assist with these issues I am experiencing.
Thank you
Ben
