[ADDED] removal of default profiles
Posted: Sat Feb 22, 2014 3:44 am
by 3ntrlab
Why on earth I should get my profiles on the bottom of the list ?
If used doesn't have any of the default printers, why should he care to scroll them every time he needs to change machine behaviour ?!?
In a professional setting this is really an annoying thing.
Best Regards
Davide Ardizzoia
Re: Feature request: removal of default profiles
Posted: Mon Feb 24, 2014 9:55 pm
by rsilvers
I would like to see the profiles handled a differently.
1 - Any profile should be removable.
2 - Rather than export and then import and then have to hit "save" to add a profile to the list, I would keep the import and export buttons so that we can email profiles to each other, but also just have a save button right there that stores a profile into the list. So:
SAVE REMOVE
EXPORT IMPORT
Also, profiles that I create should not have a visible .fff extension in the name.
And the Save at the bottom of the large dialog should not effect those.
Posted: Tue Mar 04, 2014 1:20 pm
by vinny1575
+1
Posted: Thu Jul 09, 2015 7:42 am
by S3D-Jason
Version 3.0 only shows the profiles you have requested. You can also easily click Remove and select which profiles you want to remove from the list.
