Problem with printing
Posted: Wed Feb 22, 2017 6:33 am
by shtastie.ivanova
Hello, I'm a new user of this software. I have a problem. I printed with one kind of PLA. After that i change with other kind of PLA filament. After the change the printer stopped print. The printer is printing but the filament not to extrude. I don't know, what i do. Could you tell me what i s the problem?
Re: Problem with printing
Posted: Wed Feb 22, 2017 7:04 am
by brian442
Clogged nozzle, stripped filament, wrong extruder temperature... there's a bunch of things it could be
Posted: Thu Mar 09, 2017 8:56 am
The problem is the nozzle above the heater needs to be removed because you most likely have a small ball of material which will not allow new filament to be pushed through. Need to remove this and clean it out. You may be able to remove it with a pair of p needle nose pliers. One way to prevent this is first extruding a bit then removing the filament.
