Lasso or brush tool for removing large areas of supports
Posted: Wed Feb 22, 2017 8:10 pm
Would be great to have a lasso selection tool to select large areas of supports then hit delete. I always use 1mm support resolution to get into the tightest areas and when you have support you don't need, you have to click every single separate support column when deleting. I've clicked hundreds of times just to remove an area of supports and it's a pain! Could you please consider a tool that can select large areas of columns so you can delete? Even if it's s brush. That would be great!!!
