[SOLVED] Slice is adding extra wall and bringes...
Posted: Sun Feb 26, 2017 8:09 pm
by Bluemeane
Please look a the pictures, and tell me why this is happening??
Re: Slice is adding extra wall and bringes...
Posted: Mon Feb 27, 2017 2:21 am
by horst.w
Attache your STL-File, there is an additional bridging, mostly caused by issues of the model.
Regards
horst.w, GER
Posted: Mon Feb 27, 2017 5:47 am
by brian442
Most likely a problem with your STL file. Run the S3D repair checks to see if it identifies problems. If it does, then you need to repair the STL file first.
Posted: Tue Feb 28, 2017 3:48 pm
You could try a little trick to work around the issue. It may work....
Add 0.0001 to your layer thickness. If it doesn't work first time try adding the same amount again say up to a max of 5 times.
If it works...it works. If it doesn't, you'll need to get your stl repaired,
Posted: Wed Mar 01, 2017 8:19 pm
by Bluemeane
Here is what I am trying to slice:
http://www.thingiverse.com/thing:1763518/#files
Posted: Wed Mar 01, 2017 8:25 pm
by Bluemeane
dkightley wrote:You could try a little trick to work around the issue. It may work....
This worked!!!
Posted: Wed Jul 19, 2017 10:13 pm
by wbarber69
so what do you do if the stl is manifold, there are no problems and youve tried adding .0001 to the layer height and it keeps on adding random layers where they shouldnt be?
Posted: Thu Jul 20, 2017 1:41 am
by brian442
wbarber69 wrote:so what do you do if the stl is manifold, there are no problems and youve tried adding .0001 to the layer height and it keeps on adding random layers where they shouldnt be?
I would suggest starting a new thread and attaching your factory file there
