different extrusion widths
Posted: Wed Mar 01, 2017 1:32 pm
I'd really like to use more s3d and less slic3r 'cause of the whole process ability and manual support but some things are still too problematic ... this one is a particularly big issue for me that makes me go with meshmixer+slic3r instead of s3d
attm in s3d I can only select "Extrusion width" per process per extruder. This is not enough
. I really need, often, to set different extrusion width for different extrusion types so I want for e.g. 0.48mm for inside perimeter, 0.5mm for infill, 0.45mm for support, 0.38mm for outside perimeter and for e.g. 0.55mm for top and 0.6 for bottom layer.. ideally all that different for top, middle and bottom layers
neither the slic3r have them all they have few more compared to 3 ones s3d currently offers, we have "general width" and "infill extrusion width %" and on layer we have "first layer width%" .. so slic3r is in no way solving the problem completely neither..
the minimum that I think is needed would be
- add on support tab, like for infill tab "support extrusion width %"
- add on layer tab Width % for the "outmost perimeter"
for me that would solve more then 50% of the problems I have with s3d (other 40% are related to bridges and 10% are small not very relevant things)
