Robo R1 Plus Dual Extruder Profile
Posted: Fri Mar 03, 2017 6:07 pm
by crombiecrunch
When I try to run the dual extrusion wizard it tells me i dont have a valid profile. There is none that I can see in the setup wizard for the robo r1 plus.
Re: Robo R1 Plus Dual Extruder Profile
Posted: Sat Mar 04, 2017 7:35 am
by brian442
Isn't the R1+ only a single extruder machine? It looks like the S3D profile for that machine is also single extruder only. So if you're using that profile and that printer, then yes, it's probably setup for a single extruder by default. That's why you're getting that error.
Posted: Sun Mar 05, 2017 1:26 am
by crombiecrunch
Ive added a second extruder to it. I know you can setup cura for the dual on the robo r1 plus. But I much rather use the software i paid a small fortune for.
Posted: Fri Jun 16, 2017 11:59 am
by BLRussell66
How did you add the extra extruder? All my ramps are used.
