I am printing a box with a large flat surface on the inside. it also has small features which "interrupts" the flat printing and causes visual defects where the printer skipped an area and came back. I'm sure you have all seen this. Here's a picture that shows it very well:
Now I know I have some nozzle dragging, which I am working on. What I am referring to here though is the right to left artifacts that exist from the printing "skipping" areas when it hits those small features and doing only infill under them.
What I would like to do, if possible, is print those flat areas solid as if there were no features on them. I hope that makes sense. If I have a large flat area I want to print it solid in one pass and sort of ignore the face that there's a feature there till it gets to that layer. Does that make sense?
