Page 1 of 2
Check this minimum fill system from MB
Posted: Mon Mar 20, 2017 3:12 pm
by SHoutzager
https://www.makerbot.com/media-center/2 ... ot-minfill
Simpliy3d should have this featrue. I know it can be done in Simplify but takes a number of steps to accomplish.
Steven Houtzager
Re: Check this minimum fill system from MB
Posted: Mon Mar 20, 2017 5:27 pm
by horst.w
Sure, nice to have!
But really needed?
To minimice infill, I think no.
To make possible an inside-support, I think yes. But there are mostly constructive solutions possible doing the same effect.
My ViaCAD program allows to cut out a section from inside of a solid body and so it is possible to create thin walls like support. But never needed for my objects.
Regards
horst.w, GER
This pic shows what I mean:
Clear! for a simple cylinder a function like ViaCAD's CutSection is not needed, to draw this ThinWall ist easy. But there are also existing complicated sculpts where a cut through is not possible or to difficult to draw.
Posted: Tue Mar 21, 2017 12:39 pm
by wfcook
I'm not to impressed with this actually. It seems to be a way of producing very weak parts. I'd rather see cubic infill
Posted: Tue Mar 21, 2017 2:24 pm
by Nandox7
I actually would welcome this.
It may not be something to use for every single part but for doing quick prototypes.
Actually that is exactly what they mention.
"As we’ve learned from professional users, not all prints need to be durable, dense, or heavy. When surface quality and print speed are more important, MinFill is a far more efficient option — especially for prints with a large internal volume."
Posted: Tue Mar 21, 2017 3:06 pm
Just to illustrate how opinions can differ...I disagree with both of the last two posters. I believe that S3D should address where it fails to do what it is supposed to do...... way before adding any fancy infill techniques.
No slicer should extrude into fresh air or produce an object deliberately with bits missing! Or only half do bridging. Unfortunately, S3D does!
Posted: Tue Mar 21, 2017 4:57 pm
by upsm
All new infill types are welcome in my opinion, strong, weak, fast, slow.. there can never be too much infill types, but I agree with dkightley, there are many serious flaws I'd love to see fixed (top/bottom handling between processes, solid layer to infill transition on edges, proper bridging and many more) before I'd invest energy into new infill types.
Posted: Wed Mar 22, 2017 7:47 am
by brian442
This would create ridiculously weak parts since they would have no sideways structure. So you save printing time, but the parts would fail under the slightest load.
Posted: Wed Mar 22, 2017 5:15 pm
by upsm
brian442 wrote:This would create ridiculously weak parts since they would have no sideways structure. So you save printing time, but the parts would fail under the slightest load.
For rapid prototyping that's very often acceptable!
Posted: Sat Mar 25, 2017 12:51 am
by 3Drasle
dkightley wrote:Just to illustrate how opinions can differ...I disagree with both of the last two posters. I believe that S3D should address where it fails to do what it is supposed to do...... way before adding any fancy infill techniques.
I totally agree, but are S3D team still working on updates and fixes?
Posted: Sat Mar 25, 2017 6:05 am
by brian442
3Drasle wrote:are S3D team still working on updates and fixes?
Yes, they've already posted many times on this forum saying they're working on another big release right now
