Higher Support Material Resolution
Posted: Mon Mar 27, 2017 6:45 am
One of the types of prints I have been asked to do most frequently are models of fairly large complex molecular structures, these typically consist of hundreds of approximately 2-3mm in diameter and around 10mm in length stems which link together (often in very random directions) to form the molecular structure.
When printing these they obviously require a heck of a lot of support material and inevitably result in multiple areas where the print partially fails. The support material can sometimes take around 4 hours to remove, I meticulously pick at it with wire cutters, tweezers and a scalpel.
One of the main reasons that the prints partially fail is because the support material resolution is not fine enough. I set it to 1mm; imagine a 3mm diameter stem, 10mm long with a full radius at either end standing vertically (standing up on the radiused end); I appreciate this is a challenging print for any printer/slicer. What I need the slicer to do is to calculate support material throughout the radius and print a kind of basket around it, fully supporting it but with a maximum resolution of 1mm what I end up with is is a tiny little 1mm square pad that the radius sits on, which inevitably gets knocked off on the 2nd or 3rd layer.
So far, the only printer slicer I have ever managed a full, successful print of these structures is the Up plus 2 printer with its own software which automatically calculates support material to a higher resolution than S3D will allow.
I believe all of my problems could be solved by allowing even 0.5mm resolution for support material calculations and I certainly believe this should be very simple to implement?
