Creator running on MG Mendel Prusa
Posted: Mon Apr 01, 2013 8:39 pm
by Lateralg
I'm connecting to Com2 (only port available) at 115200 with Pronterface, but unable to connect @ any bps with Creator.
Device manager says "Arduino Mega 2560 (COM2)"
"This device is working properly"
Win7 SP1 32 bit.
I suspect firmware ... I don't think I have Marlin.
If that's the case, I'll need hand-holding in getting set up.
I've done OK tweaking configuration.h when using Pronterface, but have no idea what to expect in the Marlin arena.
Question: Can velocity settings in Creator be expressed in mm/second?
Re: Creator running on MG Mendel Prusa
Posted: Tue Apr 02, 2013 6:42 am
by Simplify3D
What firmware are you running? Creator works with Marlin and Sprinter out of the box, but yes, there will be a few changes for a different firmware type. When you connect to the firmware using Pronterface, what do you see in the communication log? The Marlin firmware usually sends a "start" response when successfully connected.
Posted: Tue Apr 02, 2013 11:02 am
by Karl_Williams
I have to hold the reset button down for 4 seconds on my Gen6 board every time before Creator will connect so give that a try. All the other software I've used connects without having to press the reset.
Posted: Tue Apr 02, 2013 3:40 pm
by Lateralg
Simplify3D wrote:What firmware are you running? Creator works with Marlin and Sprinter out of the box, but yes, there will be a few changes for a different firmware type. When you connect to the firmware using Pronterface, what do you see in the communication log? The Marlin firmware usually sends a "start" response when successfully connected.
I'm in AZ, so probably 3 hrs behind you.
Running Sprinter:
With Pronterface, "Connect" command, I get:
Connecting
Start
Printer is now online
ok T:0 B:0
Running Creator:
Attempting Connection at COM2
Connection Failed
BTW: Based on recent WIKI comments on Marlin, it has very significant advantages over Sprinter. I'd like to go to Marlin, but need help in getting there.
Posted: Tue Apr 02, 2013 3:41 pm
by Lateralg
Karl_Williams wrote:I have to hold the reset button down for 4 seconds on my Gen6 board every time before Creator will connect so give that a try. All the other software I've used connects without having to press the reset.
No luck. Thanks for jumping in Karl.
Posted: Tue Apr 02, 2013 8:46 pm
by Simplify3D
I have a feeling this is related to some older boards that don't reset properly when a new serial connection is initiated. Karl has done some great troubleshooting previously, and I'm fairly certain the Gen6 falls into this category. We're planning to fix this for the 1.0.7 update, which is in final testing now.
Posted: Tue Apr 02, 2013 9:39 pm
by Lateralg
Simplify3D wrote:I have a feeling this is related to some older boards that don't reset properly when a new serial connection is initiated. Karl has done some great troubleshooting previously, and I'm fairly certain the Gen6 falls into this category. We're planning to fix this for the 1.0.7 update, which is in final testing now.
Sounds good. In the meantime, I'll try printing with Pronterface using G-Code generated by Creator. Dang, but Creator slices fast!
BTW- regarding velocity units: Sure enough, in the executing G-Code, the units are mm/minute. Didn't notice that before. The reason for my concern was that the settings in Pronterface are in mm/second. Has anyone else raised this issue?
