DannyBoy2k
Raise Extruder At End of Bed Leveling Wizard
I've been emailing support on this one, but just found this forum section and wanted to put it here too.
I have a Flashforge Finder and have been using it's bed leveling feature with the sensor that swivels on a servo. However, I found the servo wasn't always centering properly and the bed wasn't truly level at the end of the process. I then discovered Simplify3D's bed leveling wizard and it worked perfectly to help me level my bed. HOWEVER, at the end of the process, once you click the "Finish" button, it attempts to home the extruder without lowering the bed. As the Finder's bed has a plastic lip all the way around it, this caused the nozzle to crash into the bed.
The Bed Leveling Wizard raises the extruder between leveling moves, so it seems like it would be a simple and easy change to also raise the extruder at the end of the leveling process before you attempt to home it. When I emailed support about this, they said I should just use the Finder's leveling process, but, as I stated above, it's not accurate enough and the Bed Leveling Wizard in Simplify3D worked much better. Just need to lower the bed before homing the extruder at the end.
Thanks,
Dan
