Bottom Layer Horizontal SizeCompensation
Posted: Fri Mar 31, 2017 5:54 pm
I've had a few situations where, in the process of using a thicker bottom linewidth, or while printing complex print-in-place designs like geared bearings, where the bottom most layer glues together (or leaves energy sucking flaps) on the outermost edges of the bottom layer of the part.
I propose the addition of a Horizontal Size Compensation option which is applied ONLY to the bottom layer.
This could keep parts which clear on the second layer also clear on the first. Setting line width smaller would leave gaps, and multiple processes is a slightly complex work around.
Thanks!
Thanks!
