[ADDED] delete individual parts from an stl assembly
Posted: Sun Mar 02, 2014 2:55 pm
by steve
I would like to be able to select individual components/parts from an stl assembly and remove them. Some files on thingiverse (I'm thinking of Emmett's latest heart gear file) come as an assembly/build platform and it requires a third party programme to remove parts of the assembly. With the new sequential print feature it would be handy to break apart stl files into individual component parts.
Re: feature request delete individual parts from an stl asse
Posted: Tue Mar 04, 2014 12:05 pm
by vinny1575
This is exactly what I need. Cura (Free) has this as well.
Posted: Wed Jul 09, 2014 9:40 am
by DonaldJ
+1
Repetier has a split function, which allows you to manipulate/delete parts from complicated assemblies.
Posted: Wed Jul 09, 2014 3:44 pm
by hackeng
+1
Posted: Thu Jul 17, 2014 11:37 am
by joesoap583
You can do this very easily with TinkerCAD. Just load the STL file using the import options on the top right, then put a 'hole' shape over the bit you don't want to print.
This can be useful if you wanted to create a flat surface (or mounting holes) which you want to mount extra design onto the STL object - just slice the STL with the hole, group, and add your extra stuff.
Posted: Thu Jul 17, 2014 6:43 pm
by DonaldJ
joesoap583 wrote:You can do this very easily with TinkerCAD. Just load the STL file using the import options on the top right, then put a 'hole' shape over the bit you don't want to print.
I've done that a lot in TinkerCad, but performance really suffers with busy/complicated STLs. Had the program hang a few times, and refresh rates can be annoyingly slow.
If Repetier can split STLs, so can S3D (unless it requires proprietary voodoo).
Posted: Fri Jul 18, 2014 2:46 am
by joesoap583
I know the folks at TinkerCAD have done a lot of work in the recent past with server components. It may be that if your experience isn't very recent then the situation may have improved.
However I haven't tried to do anything complex with imported STL files, so you may be correct.
Posted: Fri Jul 18, 2014 8:01 am
by TenKOhms
in regards to emmett's latest heart gears, if you look at the remixes, someone has separated his files:
http://www.thingiverse.com/thing:244146
Posted: Fri Jul 18, 2014 1:25 pm
by joesoap583
TenKOhms wrote:in regards to emmett's latest heart gears, if you look at the remixes, someone has separated his files:
That's what I do too:
http://www.thingiverse.com/thing:389306
Posted: Thu Jul 09, 2015 9:57 am
by S3D-Jason
Version 3.0 added the ability to split a part into connected surfaces so that you can easily work with each part individually
https://www.youtube.com/watch?v=g1V-5aA03dQ
