Feature request heating
Posted: Mon Mar 03, 2014 5:14 am
by toto44
Hello, I have a Leapfrog creatr, and it takes lightyears to start a print, becuase of the heating. When I print using one Extruder only, the print will not start until the not used seceond Extruder has reached his set temp.! Why is the sec. Extruder monitored, when it is actaually not in use?? Can you Change this?
Additinally the Extruders overheat a lot before they come to the set temp., roughly 20C. Means wehn the temp is set to 245C, it heats up to 265C and then slowly Comes down. Think this could be optimized with the PID Setting?
Thanks
Toto
