Default extruder in Extruder Lists
Posted: Tue Apr 25, 2017 4:38 am
I have a dual extruder Vertex K8400. If I am only using one extruder (Right) I still use the dual profile but select 'Right Extruder Only' under 'Auto-Configure Extruders'. However the extruder lists under the Extruder & Temperature tabs always select the Left extruder as default when I open Process Settings. It's only a minor annoyance and I normally remember to check & switch but sometime in a rush I make changes to the unused extruder.
Is there any way to change this behaviour or can it be fixed in a future release?
