marjamar
Changing printer using "Configuration Assistant" crashes S3D
Title says it all.
This has been a plague since day one for me. I have multiple printers and in order to change S3D to use a new printer, I have to uninstall it completely first, reinstall and then configure the printer I need. My only answer to the lengthy issue is to have multiple computers, which isn't good enough as we have 7 3D printers here. Support does not have any answer, I am wondering if anyone has a fix for this.
Thanks.
-Rodger
Re: Changing printer using "Configuration Assistant" crashes
So once you load Printer A and then go back to the configuration assistant to load printer B it crashes?
marjamar
wirlybird wrote:So once you load Printer A and then go back to the configuration assistant to load printer B it crashes?
Correct. It will also crash at times if I update a profile. There is and has been something buggy in this software on this particular computer. We have it on 2 other computers (Intel CPU's) and seems OK. Problem is, this is the computer we use mostly for this work and it's my workstation computer. So, unless I go to someone else's computer or have them do something for me, I have to do a uninstall and reinstall. None of these options is to my liking very much.
-Rodger
