[ADDED] Prime pillar with changing layer heights
Posted: Thu May 11, 2017 9:41 pm
by ViperZ
Hi
I use multiple processes and output small things.
0 ~ 0.3 mm → Layer Height 0.1 mm (to obtain strength)
0.3 mm ~  → Layer Height 0.05 mm
However, PrimePillars can not be used.
It is essential to use PrimePillars for cooling.
Thank you.
Re: prime piller
Posted: Sat May 13, 2017 1:29 am
by ViperZ
I would like to use the ooze shield as well
Re: prime piller
Posted: Thu Jul 27, 2017 10:33 am
by S3D-Jason
I am happy to say that this should now work correctly with the newly released version 4.0. You can now use multiple processes with the prime pillar, so if you wanted to have 1 process with 0.1mm layer heights, and a second process with 0.05mm layer heights, that will work fine in version 4.0.
