E3D V6 inconsistent layers
Posted: Tue May 16, 2017 7:58 am
I have installed E3D V6 hotends on my Vertex K8400 and I am trying to tune the settings.
I now have most things OK, but I see severe inconsistency in the outer shell and the top layer is not covering the infill completely.
I attach a picture of an example - it's a 40x40 cube with Z reduced to 10mm for quicker completion.
I don't think it''s actually an S3D issue but maybe someone has ideas. I looked at the Quality Troubleshooter, and I'm afraid it may be a mechanical issue, although the filament is probably at least 1 year old so may not be the best quality any more.
It appears to print the bottom layers OK then there's about .3 - .4 mm with very poor sides, then it improves. Then there's a narrower section before the final couple of mm, which print OK.
I'm printing PLA 0.1mm @210°. Cooling is on permanently, extrusion multiplier was 1.2 for this test (I've tried various values), and width is auto. I defined 3 perimeter shells (outside-in). I have 8 bottom layers and 10 top layers
Any suggestions are appreciated
John
John
