Skynet Firmware
Posted: Wed May 17, 2017 10:02 am
by smeek
Hello, first post here. I am wondering if anyone is using S3D with the Anet A8 Skynet firmware. I am considering installing this firmware. I have been having good luck with the factory file supplied for my printer. Will I continue to be able to use the factory file as is? Will the firmware modifications setting have to changed? Thanks!
Re: Skynet Firmware
Posted: Thu May 18, 2017 4:44 pm
by MasterFX
I'm using Skynet Firmware on my A8 without any problems. Since it is only a slightly modified Marlin Firmware there is no problem.
You don't have to change any parameters in your Profile which you have used with your stock firmware.
Re: Skynet Firmware
Posted: Fri May 19, 2017 12:31 pm
by smeek
MasterFX wrote:I'm using Skynet Firmware on my A8 without any problems. Since it is only a slightly modified Marlin Firmware there is no problem.
Thanks!
