Horizontal Size Compensation Causing Quality Issues!?
Posted: Mon May 22, 2017 11:47 pm
Anyone using Horizontal Size Compensation (HSC) setting seeing strange behaviors (inducing ripples/wobble)? In the image, the top (1) and bottom(5) are printed at 60mm/s without HSC enabled. Prints 2-4 has -0.24mm for HSC. Prints 2 and 3 are based on the same gcode: -0.24mm HSC, 50mm/s, printed back-to-back. Print 4 has -0.24mm but at 60mm/s.
In summary:
1) 60 mm/s, 0mm HSC (baseline)
2) 50 mm/s, -0.24mm HSC (large ripples and a semi split layer)
3) 50 mm/s, -0.24mm HSC (large ripples)
4) 60 mm/s, -0.24mm HSC (ripples)
5) 60 mm/s, 0 mm HSC (back to baseline)
The printer is Robo R1+ with Micro-Swiss 0.4 nozzle. Running Marlin 1.1.1-Mesh Leveling
The material is 1.75 (~1.70 actual) eSun Silver PETG printed at 240/75
Some of other common settings: Layer=0.20mm, Retraction=1.5@30mm/s, Z-hop=0.8, Coast = 0.2
STL used: http://www.thingiverse.com/thing:277394
