Feature request: First Layer
Posted: Sat May 27, 2017 10:11 am
Hi Simplify3D
I would like to request some options in the First layer section.
I really like the way you are doing it right now but it would be even better if i could define it to be more strict such as:
Specify first layer as in layer and not in percentage. 0.2mm layer height or whatever i wanted for the first layer height.
So it wouldnt matter if i was print 0.2 , 0.1, 0.05 layer height it would always stay 0.2 for the first layer.
The same goes for the other options, it would be awesome if it was possible to get the same settings like in the first tab (extruder) .
Where as you define the width in mm and not in percentages.
It could be a form of select either this option or the regular option
Thanks.
Thanks.
