Bug: Sparse infill every x layers speed.
Posted: Tue Mar 11, 2014 7:22 am
When I use print sparse infill every 3 layers, the 2 layers with no infill perimeter speed slows down to the speed set by "support structure under speed."
When the print gets to print the layer with the infill, the perimeters speed back up to normal speed. The only way to fix this is to turn up "support structure under speed." to match "outline under speed".
This is really annoying as I'm printing at 0.1mm layer height and hence infill is 0.3mm every 3 layers. and want to use this feature to speed my prints up..
I hope this post makes sense, and trust that this nasty bug will be fixed.
This really is the best Slic3r I have used.
David
David
