beemergb
Not homing after ending printing
Hello ,my 3d Printer has just stopped automatic homing on finishing the printing program , it stops dead on the last Point , when it should then return to its home position .Any ideas what is causing this ? Hope you can help .
brian442
Re: Not homing after ending printing
Add a homing command at the top of your ending script.
You can read about the command to add here:
https://www.simplify3d.com/support/arti ... orial/#G28
xTremePower
Hello !
One important thing : Think it's a 3D printer !!!
NEVER home after a print ! it's dangerous for your printer and printed object
Depend of your 3D printer, but in many cases, like mine, if I home when the print are finished, the center bar simply go down on printed piece and explode them !
I prefer use a softer mehod added some lines to the End script like this :
G91
G1 X10 Y10 Z10
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M107 ; disable fan
M84 ; disable motors
The second line is the most important : it move the extruder 10mm more on X Y Z at the end
it prevent the end of hotend to burn the printed object and was enought on any print
Go home is useless because in any case, when you start a print, the printer make a Home All :p
brian442
xTremePower wrote:NEVER home after a print ! it's dangerous for your printer and printed object
You are correct that homing ALL axes or the Z axis after a print is completed may cause problems. But in this case, homing the X or Y axis should be fine. That won't run into the previously printed part.
