Dual extrusion can't Offset
Posted: Thu Jun 01, 2017 6:25 pm
by xTremePower
Hello,
I buyed S3D specially for make dual extrusions, but I can't setup the offset ..
I have a Zonestar D805 dual (Repetier firmware)
after a couple of hours I am totally unable to setup the dual extrusion ....
I tried all this things :
-Setup the offset in Options , machine , toolhead offset, I tryed to set many values for extruder 0 and 1 bot it's change nothing
-Tied to change same values in FFF setttings in g-code tab, change nothing
-Tried to include the offset in the G code with Apply toolhead offset in gcode coordinates, the printer use only a single color (and wery awfull model preview ...)
-Changed the offset directly on the printer screen, when I launch the print, he reset all values to default...
How can I set this Offset please ?
Re: Dual extrusion can't Offset
Posted: Mon Jun 05, 2017 6:57 am
by brian442
You might want to read this:
https://www.simplify3d.com/support/faq/#faq-4709
It pretty much explains every option you have to adjust the toolhead offsets
