Infill only above certain thickness?
Posted: Fri Jun 02, 2017 2:09 pm
by LesB
I have a relatively complex engineering part I wish to print partly solid without infill. The parts I want solid are only 2 or 3mm thick but there are many bumps and projections and a few much thicker parts which can and probably should be partly hollow. Is it possible to define that infill is only applied to parts thicker than say 3.5mm or some other defined value?
