Is there a way to duplicate objects on the build platform instead of loading each one?
My issue is in trying to print a few of a part, which needs to be rotated. Hence, I need to load each one individually, then double click on the part, then type in the new xyz rotational coordinates. Time consuming. Would be great to load one, rotate it correctly, then copy that same one multiple times.
