Slicer removes chunks of the model
Posted: Thu Jun 15, 2017 12:37 am
by latreides
I have a model I downloaded from thingiverse and when I slice it, it has large chunks removed. Its really bad at 0.2 mm and just bad at 0.1 mm
Here is the section of the model:
Here is the same section in the gcode preview at 0.1 mm layer height:
Does anyone have any idea as to why it would do this? I tried to attach the factory file but its too big for the forums. I am using the model from here:
https://www.thingiverse.com/thing:855731
I had to scale it to 770.52 % size because S3D loaded it as a really really tiny model. I also lowered it to -0.40 on the Z axis to get the back feet to touch the build plate.
Re: Slicer removes chunks of the model
Posted: Thu Jun 15, 2017 4:45 am
by smeagollum
That's a really crappy model. I tried using the separate connected shells feature in S3D, but that causes S3D to choke, and become nonresponsive, so I suspect the model has loads of self-intersecting triangles.
Did you try running it through a repair service before slicing? I did a quick test with makeprintable.com, and that seems to fix the model so it can slice correctly in S3D.
Posted: Sat Jun 17, 2017 10:54 am
by latreides
Thank you for your suggestion. Fixer websites did remove that particular issue.
The model "looks" solid, so why would S3D slice it with huge gaps?
Posted: Sat Jun 17, 2017 1:59 pm
by MasterFX
latreides wrote:Thank you for your suggestion. Fixer websites did remove that particular issue.
It looks like one solid, but it isn't. This are multiple objects:
Posted: Sat Jun 17, 2017 2:42 pm
Use the Separate Connected Surfaces option on the Mesh menu.
If there are multiple meshes, the model count will increase....and if so, just slice as normal.
