help with abs please
Posted: Thu Jun 15, 2017 6:43 pm
by 14k
hi
I have not long had my FlashForge creator pro, i am having some problems with printing ABS. when i print with PLA it comes out perfect but when in use ABS its like the print starts to "melt" is the best way to describe it has anyone had the same problems ??? driving me nuts trying to fix it any help will go down a treat.
cheers callum
Re: help with abs please
Posted: Fri Jun 16, 2017 7:40 am
by wirlybird
Really need more info. Slicer, temps, speeds etc, factory file would be helpful.
What is the model?
Posted: Fri Jun 16, 2017 12:28 pm
by MasterFX
Pictures of your problems please!
Posted: Fri Jun 16, 2017 4:13 pm
by red104
Go ahead and throw up the Factory File on dropbox, google drive, etc. Drop us the link to the file and we can take a look.
And yes, please post pics on Imgur, etc. That will help out tons!
I have a FFCP, and ABS comes out great on the factory settings albeit I have the nozzle temp at 220c.
Are you using the stock ABS that came with the printer?
Posted: Fri Jun 16, 2017 7:52 pm
by upsm
usually happens
- bed too hot
- env too hot
drop the temp of the bed after first layer (1st layer 90-110C what lowest that gets you good adhesion, second+ layer 60C) and if not enough add few % (lowest your fan will spin, 10% for e.g.) cooling even with ABS
Posted: Mon Jun 19, 2017 5:47 am
by 14k
hi sorry for the late reply, im new to all this so sorry if i ask somewhat stupid questions, just tryin learn
im using a flashforge creator pro
heres the pictures of what i mean by "melting"
http://imgur.com/a/6UtX2
i think ive done it right heres the FFF.
https://www.dropbox.com/s/sa07v4f1miyvgh8/abs.fff?dl=0
included the printer info aswell if this helps any
http://imgur.com/vuNcjGa
cheers
14k
Posted: Mon Jun 19, 2017 3:54 pm
by jfkansas
The problem is with playing with the bed temp too much is it is the principle heater for the build chamber. Most run the build plate too hot, 95c is about right for ABS. Any lower and it won't keep the build chamber hot enough.
Posted: Tue Jun 20, 2017 6:01 am
by MasterFX
red104 wrote:Go ahead and throw up the Factory File on dropbox, google drive, etc. Drop us the link to the file and we can take a look.
No need to use an hoster, it can be uploaded here
Posted: Tue Jun 20, 2017 4:35 pm
by upsm
That looks like a classic "bed too hot" issue. Drop the bed temp after the first layer.
