dual extrusion
Posted: Thu Jun 29, 2017 2:42 pm
by 14k
hi
has anyone got any advice, I am trying to print a box using dual extrusion on a Flash Forge creator pro. I have split the box in half and created 2 stl files. have run the dual extrusion wizard, follow all the advice on the s3d YouTube channel. when i print the two halves either over lap or have almost a 10mm gap between them, i have joined the 2 objects together. i am clearly missing something can any one point me in the right direction.
cheers
callum
Re: dual extrusion
Posted: Fri Jun 30, 2017 5:20 am
by brian442
What printer are you using? Does the overlap only show up when you click "Prepare to Print" or does it look that way when you are arranging the models as well?
Re: dual extrusion
Posted: Fri Jun 30, 2017 6:27 am
by 14k
hi
i am using a Flash Forge Creator pro. they model looks fine all through the process just as soon as it starts to print it either overlaps the 2 halves or it creates a gap. the model on s3d looks perfect.
cheers
callum
Re: dual extrusion
Posted: Sat Jul 01, 2017 4:48 am
by brian442
Well if the preview looks correct, but when you start printing it, the different nozzles are shifted, then that would mean the toolhead offsets on your printer are incorrect. I see a lot of people who have the offsets set incorrectly due to errors in the Sailfish firmware installation process, so if you installed that firmware recently, that may be what happened.
There is a lot more info here:
https://www.simplify3d.com/support/faq/#faq-4709
