RogerWilco486
Re: Request: Firmware Retraction
Mon Jan 07, 2019 11:00 am
OP here, still waiting for this feature.
Eddiie
Fri Jan 11, 2019 12:17 pm
+100 for a checkbox that does the search/replace behind the scenes.
Why is this so difficult to add this?
alexspeller
Wed Jan 23, 2019 5:56 pm
I found, at least on the latest version, that the M101/102/103 generated more retracts than would otherwise be the case.
I fixed this by using some bogus retraction settings and replacing that instead, e.g. 0.1mm at 6666mm/min. Make sure not to set Z hop as that will come out as a separate move.
Then I replaced the actual retraction gcodes with this script:
{REPLACE "G1 E-0.1000 F6666" "G10"}
{REPLACE "G1 E0.1000 F6666" "G11"}
This resulted in 25% less G10 calls in a sample test print, which came out looking better for it.
smoki3
Wed Feb 13, 2019 3:41 am
1+
Would be great if they can support this
Wallabear
Wed Feb 13, 2019 4:44 pm
I would really, really, REALLY like to see this feature add as well
