Feature request: Z lift on long travel moves
Posted: Thu Mar 20, 2014 2:05 pm
by barsam
It would be nice to have the option to lift Z on long travel moves where there is always the danger to knock down sensitive objects.
Now the only option is to lift Z when there is a retraction. Some times there is a retraction at very small moves and the lift is unnecessary.
Re: Feature request: Z lift on long travel moves
Posted: Fri Mar 21, 2014 6:33 am
by JoeJ
Other tab, set minimum travel for retraction
Posted: Sat Mar 22, 2014 6:22 pm
by barsam
That's for retraction again. I want to retract even at small moves, I just don't want to lift that often.
Posted: Sat Mar 22, 2014 11:42 pm
by JohnB
barsam wrote:That's for retraction again. I want to retract even at small moves, I just don't want to lift that often.
+1
Posted: Wed Jul 29, 2015 10:49 am
by il_performante
I too think there is the need for a Z rise when crossing over support structures and actual print.
It should be user defined as retract +Z 0.1 to +Z0.5 or more.
To be used on rapid movements over support structures and part.
To be user definable over what minimum distance the +Z retraction move should take effect. Indipendently from Wire retraction. (ooze retraction)
I've used a stratasys MC 250 for 3 years. They have it and it's great.
Thanks.
Marco
Posted: Wed Jul 29, 2015 7:15 pm
by jimc
ok i see what everyone is saying but does it really bother you that it currently lifts z on short moves? just set it and forget about. let it do its thing. its not hurting anything
Posted: Mon Aug 03, 2015 12:11 pm
by C-line
+1
I agree with the OP that lifting only on travel moves greater than a set distance is preferable to lifting on all retractions. Unnecessary Z-lifts slow down the print and can lead to blobbing and other artifacts.
