4.0 pillar height?
Posted: Wed Jul 26, 2017 1:50 pm
by RudydG
Can't find the height limitation setting. Probably stupid me, but can someone help me?
Txs!!!
Re: 4.0 pillar height?
Posted: Wed Jul 26, 2017 8:32 pm
by xile6
If you find out let me know i havent been able to find it either
Posted: Thu Jul 27, 2017 12:36 am
by RudydG
Found a (the?) solution, one can do it with the split processes (which is really not new, you could do this in the past, only had to set the stop and start print height yourself)
Posted: Thu Jul 27, 2017 5:07 am
by brian442
Setup a single process with the prime pillar. Then go to Tools > Variable Settings Wizard, and move the little slider in the bottom right until the plane is right where you want to stop the pillar from printing. Then click "Add Location" and accept. That will create 2 processes, one on the top and bottom of that location. Click on the top process (probably called ProcessName-2 or something like that) and then disable the prime pillar for that process. Now it stops when the first process is complete.
the prime pillar in 3.1 didn't work well at all with multiple processes, so this is already a big improvement!
