Use information about layers and distance everywhere..
Posted: Thu Jul 27, 2017 10:44 am
In preview mode, you can work with layers
In Variable settings wizard however, you work with distances, although I recognize that a visual layer can be seen for help
I believe that you should allow to work with either distances and/or layers as a choice in every situation, tool or window. This will help in some cases were a high precision is required.
In any case, i don't know the relationship between distance and layer, and this produces some discomfort and annoyance
