Variable coasting
Posted: Fri Jul 28, 2017 8:54 am
Hi.
I've moved to S3D a couple of weeks ago. I'm amazed at how simple it is to get good prints.
I'm an ABS guy. I'm mostly printing for prototyping parts using a 0.6 nozzle and sometimes a 0.8 on a bowden setup and a volcano hotend. One thing i realized is that controlling oozing and zits is a lot harder. Retraction won't help because the plastic in the nozzle doesn't get sucked in (and there is more because of the volcano). I've took a lot of time tuning the extra restart/wipe/coasting settings but one thing i realized is that coasting is the most important parameter when you use a bigger nozzle.
So yeah, here's the request and the theory behind it. In a bowden setup the hotend tends to accumulate more "pressure" compared to a direct extruder setup. The duration/length of the extrusion will change the coasting required. If i'm doing a 20mm diameter circle, it will tend to "overcoast" and i'll get holes in my surface. If i'm doing a 80mm diameter circle i'll get it just right and get a smooth seam with no zits.
One way to implement the feature would be to put a "Maximum coasting extrusion length". Then just do a linear scale down of the coasting distance if the extrusion length is under the specified parameter. That way long extrusions would get full coasting (and pressure reaches a "cap" in the hot-end at some point) and shorter ones (where pressure doesn't build as much) wouldn't suffer from the full coasting setting.
Am i making sense here or missing something?
