Highlight profile modifications
Posted: Sat Jul 29, 2017 12:03 pm
by pioneerko
When you edit something it's hard to remember what was modified when you try to fine tune processes.
It would be great if Simplify3D would highlight fields what was modified before i update and save new settings for the profile.
Re: Highlight profile modifications
Posted: Tue Jan 23, 2018 3:22 am
by Thumper3d
id love to see this feature as a new user to S3D. im having a hard time remembering the changes to the profile i had and end up having to write everything down on paper.. would be nice if it had a feature like cura 3.1 where there is a little circle arrow that reverses the change back to the last setting you had for that area....
Posted: Tue Feb 27, 2018 12:43 pm
by SDX
... it would be nice having a "Base Profile" that can't be modified easily and then see all the changes you made to it. ... and then ... making changes to the base should modify all untouched changes in the quality settings.
So lets say... the base extrusion width is 0.4mm and i have three qualities (Draft, Medium and HQ). I set it to 0.42mm in "Draft" but left it in Medium and HQ to 0.4mm. Now when I set the base to 0.45mm Medium an HQ goes up to 0.45mm Draft stays at 0.42mm. And EVEREY Parameter should be bound to the Quality settings... I hate it to set the first layer height from 100% to 200% and so on when printing with 0.2mm or 0.1mm (I'd like to have my first layer 0.2mm).
