Disable heater use a temperature of 0 degrees
Posted: Sat Jul 29, 2017 1:06 pm
I was trying to turn off the heater on the build platform for a FlashForge Creator Pro. When I deleted the setpoint and "Begin Printing over USB" I got the message:
"Each temperature controller is required to have at least one setpoint definition.
If you are trying to disable the heater, please use a temperature of 0 degrees."
So I added a setpoint for the "Heated Build Platorm" and set it to 0 (degrees C).
The build started, skipped over the Heated Build Platform step properly, heated up the nozzle, and then stuck in the Preheating... stage, never starting the print.
The Preheating... progress bar on Simplify3d was stuck at 25% even after the printer had reached full temperature.
