[SOLVED] First layer doesn't stick unless using a raft.
Posted: Mon Jul 31, 2017 7:33 am
Currently, I can only get my wanhao i3 to print something if I use a raft.
If I try and print something without a raft, the first layer just will not stick. It just clumps around the extruder head.
However, if I print the same thing with the EXACT same settings, except using a raft, it prints perfectly. I have tested one print where I printed two items in the same print, one with a raft, and one without, and only the rafted one worked out.
I just don't understand how it is only working with a raft, even with the same simplify3d settings, same leveled bed, and same distance to the extruder.
Any help would be greatly appreciated.
Thanks
Thanks
