Sailfish 7.7 doesn't see 4.0 x3g files
Posted: Mon Jul 31, 2017 3:42 pm
by f7metz
Evidently V4.0 writes a new .x3g format which Sailfish 7.7 (Flashforge Creator Pro) doesn't see. Is there a way to get back to the last build of V3?
Re: Sailfish 7.7 doesn't see 4.0 x3g files
Posted: Tue Aug 01, 2017 6:29 am
by brian442
I have Sailfish 7.7 on my printer and it sees the x3g files just fine. Are you sure you are copying the correct file onto the SD card? Is is possible there is a problem with the SD card or the card reader?
Posted: Tue Aug 01, 2017 6:55 am
by wirlybird
Mine is working also. Make sure to give it plenty of time to write the files.
Posted: Tue Aug 01, 2017 10:19 am
by jfkansas
Keep file names short, and no special characters.
Posted: Tue Aug 01, 2017 1:29 pm
Note for the OP....
The gpx.exe utility file is exactly the same file (ie same creation date/time and file size) as the file in all releases back to v3.0.1....so I can't see how a new format of file can be being written in vv4 of S3D.
Posted: Thu Aug 03, 2017 1:48 am
by Tomsull2016
brian442 wrote:I have Sailfish 7.7 on my printer and it sees the x3g files just fine. Are you sure you are copying the correct file onto the SD card? Is is possible there is a problem with the SD card or the card reader?
Make backups but try copying the old gpx.ini from the old S3D folder into the new v4 folder,
