Crash when waking from sleep and fan not turning on
Posted: Tue Aug 01, 2017 11:52 pm
by Iron Val
I like a lot of the new features added, but whenever I have S3D running then my laptop goes to sleep mode, upon awakening..it crashes every time. Windows reports that it stopped working and I have to End Task on it.
Also, My PLA cooling fan is not turning on anymore, even when I specifically told it to turn on at 100% Layer 2.
Please help!
Thanks,
Val
Re: Crash when waking from sleep and fan not turning on
Posted: Wed Aug 02, 2017 6:00 am
by brian442
Have you checked your gcode file to see if a fan command is added at layer 2?
Posted: Wed Aug 02, 2017 6:52 am
by wirlybird
On the fan part try deleting all the entries for the fan i.e. layer 1, layer 2 and re-add them and see if it helps. I found that one of my profiles for a certain printer does this periodically and if I do that it starts to work again.
The other thing is to do a reset from the help menu and add the profiles back in.
Posted: Wed Aug 02, 2017 9:44 am
by Iron Val
Thanks for your suggestions regarding the Active Cooling fan issue, guys.
