Rectangular infill only makes horizontal lines
Posted: Wed Aug 02, 2017 11:22 am
by Goryc
I installed version 4.0 but:
- Real-Time preview (0.1s) does not work; Has always worked.
- Calculation of the totally wrong printing timing (progress bar)
- Rectangular infill only makes horizontal lines
What is happening?
Re: Rectangular infill only makes horizontal lines
Posted: Wed Aug 02, 2017 12:55 pm
This is probably an issue with installing new software as opposed to an issue with v4 that is making things go wrong.
Best to advise what your machine & OS is.....and exactly what you have done to get to where you are. Then, someone with the appropriate tech knowledge of YOUR machine can try and help.
Posted: Thu Aug 03, 2017 5:04 am
by Goryc
Thank you,
The print preview I solved; Was a wrong setting.
I still did not solve the problem of rectangular infill!
Posted: Thu Aug 03, 2017 5:31 am
by brian442
Might help if you posted a screenshot or your factory file
Posted: Thu Aug 03, 2017 1:13 pm
by LHawes
If I understand your question the infill is called rectilinear I believe and you can add angles in the 'infill' dbx. I have 45 and -45 which alternate each layer. Hope that helps.
