Manual Support
Posted: Wed Aug 02, 2017 11:43 am
by 3DAli
is there anyway to choose the support infill angle when you do manual support?
Re: Manual Support
Posted: Wed Aug 02, 2017 11:55 am
by wirlybird
Try setting it under supports and see how that works. I think I did that.
Re: Manual Support
Posted: Wed Aug 02, 2017 12:48 pm
Just to clarify whirlybird's reply.......the angles of supports, either manual or automatically created, are defined in the Support Infill Angles box in the Support tab in the profile settings. You can define one or more angles by adding to the list in the table using the Add angle button and value field.
There are not different angle settings for manual and automatic supports.
Re: Manual Support
Posted: Wed Aug 02, 2017 1:15 pm
by wirlybird
dkightley wrote:Just to clarify whirlybird's reply.......the angles of supports, either manual or automatically created, are defined in the Support Infill Angles box in the Support tab in the profile settings. You can define one or more angles by adding to the list in the table using the Add angle button and value field.
Appreciate the assist!!
Re: Manual Support
Posted: Thu Aug 03, 2017 9:47 am
by 3DAli
Thanks, you are right it still reads it form there.
Re: Manual Support
Posted: Sat Apr 07, 2018 10:51 am
by airscapes
Old post but turned up on a search for Support Infill angles .. but I took a look at the tip of the day and found my answer so here is the link for the next person doing a search.
viewtopic.php?f=8&t=2135
