Adjusting wall thickness
Posted: Mon Aug 07, 2017 5:45 pm
by NealWeeks
I'm just wondering if S3D will allow me to adjust wall thickness. I have imported my own model and from certain angles parts will disappear. For instance a shoulder flare from clothes on the model. I am assuming that is because the program recognizes something as being there but not enough to actually print. Hope that made sense.
Re: Adjusting wall thickness
Posted: Tue Aug 08, 2017 6:54 am
by brian442
It would probably help if you posted a screenshot of the exact area on the model you are talking about.
But you could also try going to the Advanced tab and changing the External Thin Wall Type to allow single extrusions. The single extrusions let you print smaller features vs normal perimeters.
Posted: Tue Aug 08, 2017 9:22 am
by NealWeeks
Adjusting wall thickness - internal single extrusion
Posted: Thu Aug 17, 2017 8:46 am
by mateas
Hello,
I have problem with missing an internal singl extrusion respectivelly I not understand why I have it from layer 1to 3 and then from layer 4 it disappear. Could you help with setcorrect set up? I have 4.0.
Posted: Thu Aug 17, 2017 6:51 pm
by brian442
Seems like this would be better for a new thread...
When you make a new thread, it would also help if you posted the factory file, otherwise it's hard to help
